Results 1 to 6 of 6
  1. #1
    Street Tire
    Join Date
    Sep 2011
    South Africa
    Posts
    378
    Thanks
    14
    What to look for when Buying a H2?
    I have an itch to upgrade my stock double cab Mazda BT 50 to a Hummer H2T (I prefer the T).
    What are critical things to look out for, considering that I live in South Africa that is Right Hand drive?
    I already know of two types of left to right hand drive conversions, the belt and chain steering swop, chain one is the recommended one.
    My 2nd concern is the seating position, Im not too tall, 1.9m, but with the seat moved to the furthest rear position, my leg (front mussle) hurts from the awkward position, its almost as if the seat needs to be moved 2 inches backwards for a comfy sit down, dont know if the left had drive owners can comment on this?
    Anyhow back to the question.
    What is well known problems on H2's to look out for, takin in mind I'm looking at 2006 model 6.0 V8 with 90,000km (56,000 Miles) on the clock for R 560,000 ($ 54,900) this is so far the cheapest option available.
    Edit: The ones I test drove had the rear diflock by the radio. I assume this is the Adventure package? or how would I be able to distinguish between them?
    2010 Hummer H3 V8 Adventure:
    INSTALLED: 35" Kumho KL71, Cranked Torsion Bars, ARB Bullbar, Warn 9500XP winch, Lightforce 240 HID spots, Bullydog Watchdog, aftermarket TPMS, Safari Snorkel, African Outback Roofrack, Performance exhaust and headers, custom UC skidplate, Hunner skids, load bay box
    STILL TO BE RE INSTALLED: dual battery system and MANY more to come
  2. #2
    Spilled Milk
    Join Date
    Sep 2011
    Posts
    1,523
    Thanks
    230
    H2's all have rear diff lock standard. The Adventure package will have the air suspension set-up, which is another button below the diff lock and trailer tow buttons; if there's a blank spot then it doesn't have the air. If it does have air suspension, you could push the button once with the truck running and ALL doors closed and the ass of the truck will raise itself about a foot--it'll be noticeable. Once it's done going up, you can shut the truck off and have a walk around and check to make sure it looks level and seems to be holding.
    Some guys here will say the side mirrors tend to have problems, but there's not much you can do to prevent this. Just check all functions to make sure they work, then center the mirror left/right switch and push the mirror adjust button. One click will make both mirrors fold in and another click will have them power back out.
    Another common issue is the small switch lights on the steering wheel, dash and doors tends to burn out randomly. Once again, nothing can prevent this, and it's just mildly annoying, but it's known to happen.
    Others will chime in, but I can't think of anything else right off the top. The H2 is justifiably a great vehicle to drive and reliability is really good in my experience.
    Hope you find the right one!
    Quote Originally Posted by rascole View Post
    I'm pretty anal when it comes to poking holes in the wrong place.
  3. #3
    All Terrain
    Join Date
    Sep 2011
    Nova Scotia, Canada
    Posts
    704
    Thanks
    9
    My biggest issue is the water leak from the front of the truck.
    Also the front inner axle seals are known to go, but this is common across all GM trucks. You can easily spot this by looking where the outer axle shaft meets the inner housing (look beside the inner axle boot) - you will see a flange with bolts - check for oil around it.
    Both things being said - this is a hell of a truck and the issues are easily resolved.
    Blacksheep HUMMER Squadron : GREAT WHITE NORTH
    Taking the Blacksheep international.
  4. #4
    Street Tire
    Join Date
    Sep 2011
    South Africa
    Posts
    378
    Thanks
    14
    Thanks Guys, this info is really helpfull , please keep it coming
  5. #5
    Bald Tire
    Join Date
    Aug 2015
    California
    Posts
    15
    Thanks
    0
    Put the H2 on a lift and check the front wheel bearings, ball joints, tie rods. At that age they can be fairly worn. You will see on YouTube several videos about the H2/GM 1500/2500 truck's of the same era having the wheel bearing issue.
    Regards,
    mmesa005 2003 H2
  6. #6
    Bald Tire
    Join Date
    Jun 2015
    Costa Mesa
    Posts
    46
    Thanks
    9
    Wheel bearings - they will need to be upgraded especially if off roading, go with Timken wheel bearing assemblies and you'll be good for quite a while.
    Shocks - likely with age and or mileage will need replaced.
    Belts & tensioners for the belts, these will let go over time, especially on the AC compressor.
    Alignment - if its out it will wear tires pretty bad.
    Electrical system - check all the lights both on start up and once driven around for awhile, they develop personalities sometimes.
    Water intrusion - check passenger floorboard carpet at the top of the footwell for evidence of mold build up from past leaks.
Similar Threads
  1. H3 Buying an H3
    By amrg in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 05-07-2013, 04:04 AM
  2. CL: '06 H2 - thinking of buying it!
    By Bigunit in forum Online Finds
    Last Post: 01-22-2013, 02:48 PM
  3. WTB buying Fender Flares for 09 H3 without mud flaps.
    By davidh3 in forum The Swap Meet
    Last Post: 05-28-2012, 03:18 PM
  4. WTB Buying Stock bump stops for 09 H3
    Last Post: 04-10-2012, 06:16 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
