Page 1 of 3 123 LastLast
Results 1 to 15 of 45
  1. #1
    Low Profile
    Join Date
    Mar 2012
    El Paso, TX
    Posts
    166
    Thanks
    19
    Randy Ellis Coilover Front End Conversion
    So...after Moab and staring at 06 H3's Rancho lift, I have contacted Randy Ellis Design to do a coil over conversion. This will be coupled with replacement of the torsion bar crossmember, since it hangs so low, hydro-ram steering, and a rear spring-over. To make things cheaper, I will use a few Rancho parts like the crossmembers and diff skid. Low profile skids (UCP) of aluminum and HDPE will then be fabricated. Moderate lift (4-5") and flattening the belly should greatly improve ground clearance. I will do most of this myself with Randy Ellis designing and fabricating the a-arms.
    As the project progresses, I will update here.
    Edit: I will also be using a Warrior spring over kit for the rear. I like the stock springs and want to retain them. Which means I will have some trail duty skids for sale soon This part of the project is already underway and the final rear ride height will be used to determine final front ride height.
  2. The Following User Says Thank You to H3TBone For This Useful Post:
    MUTAINT (04-14-2012)
  3. #2
    NEVERENDING ADDICTION
    Join Date
    Sep 2011
    Mineral Bluff GA
    Posts
    254
    Thanks
    57
    06 Hummer H3
    Rancho 4'' lift
    18'' KMC Hoss wheels
    325/65r18s Fierce Attitude MT's
    ThorParts front bumper
    Daystar Upper Dash Panel
    Custom Brush Guard
  4. #3
    Join Date
    Sep 2011
    Posts
    2,542
    Thanks
    100
    Sounds awesome. Forgive my ignorance...who is Randy Ellis?
    Have you "Liked" our H4O Facebook group?
    2009 HUMMER H3T ALPHA
    See more at Hans3T.com!
  5. #4
    Low Profile
    Join Date
    Dec 2011
    San Diego
    Posts
    106
    Thanks
    0
    Subscribed.
  6. #5
    Guardian Angel
    Join Date
    Sep 2011
    Raleigh, NC
    Posts
    1,519
    Thanks
    92
    That sounds amazing. Definitely keep us posted.
    "Ex Umbris Venimus"
    Sent from my iPhone
    Facebook NC Hummer Group
    https://www.facebook.com/groups/NCHummers/
    ReconH3 Build Thread v2.0
    http://www.hummer4x4offroad.com/foru...ld-Thread-v2.0
    ReconH3 Garage
    http://www.hummer4x4offroad.com/foru...age_view&id=35
    Quote Originally Posted by goob3r View Post
    Your truck is HUMMER porn, seriously.
  7. #6
    Join Date
    Sep 2011
    Western New York/ Crawfordsville, IN
    Posts
    2,097
    Thanks
    403
    Cant wait to see this build!!
    -2008 H3 Alpha
    "Like nothing else"
    My Garage H3
    My Garage H2
  8. #7
    Capt.
    Join Date
    Sep 2011
    Jersey Shore,SouthFL, longisland
    Posts
    635
    Thanks
    148
  9. #8
    Super Swampers
    Join Date
    Sep 2011
    Finger Lakes, NY
    Posts
    2,431
    Thanks
    317
    Quote Originally Posted by Hans3T View Post
    http://randyellisdesign.com/
    2008 HUMMER H3
  10. The Following User Says Thank You to 08SolarFlareH3 For This Useful Post:
    H3TBone (04-13-2012)
  11. #9
    Low Profile
    Join Date
    Mar 2012
    El Paso, TX
    Posts
    166
    Thanks
    19
    I think this is going to be awesome, as well. It will be less complicated that Bebe's build but some similarities. No diff changes for now. A parts list will be created so that anyone can repeat it later if desired.
  12. #10
    Baja
    Join Date
    Sep 2011
    Posts
    1,006
    Thanks
    37
    Check out the FJ-Cruiser front suspension. That's basically the same thing. Never been a fan of torsion bars.
    Also you should look into adding Colorado/Canyon axle plates to the mix. I think these might bolt up to the H3 housing without any fabrication. They would add a second mounting bushing per side (instead of just one). I always thought the H3 had way too much movement at the front axle...especially after all the bushings get worn. Here's a picture of the C/C axle plates...
    Attachment 4137
  13. The Following User Says Thank You to 4speedfunk For This Useful Post:
  14. #11
    Low Profile
    Join Date
    Mar 2012
    El Paso, TX
    Posts
    166
    Thanks
    19
    Quote Originally Posted by 4speedfunk View Post
    Attachment 4137
    All great suggestions, as always,
  15. #12
    Baja
    Join Date
    Sep 2011
    Posts
    1,006
    Thanks
    37
    One more thing...
    Go back and look at that photo I posted. Is that a CAD (Center-Axle-Disconnect) solenoid right there on that C/C axle? Could this be the answer for a 2WD mode??? You could simply wire that thing to a manual switch to disconnect the front hubs. This would give you a "poor-man's 2WD":
    -Pull the front driveshaft
    -Put the T-case into 4HI-Lock
    -Activate the solenoid (or de-activate it as the case may be).
    -and TA-DA!...a 2WD H3!
    The CAD solenoid allows the front hubs to spin without spinnng the ring & pinion. I only mention this because some of us would love to disable 4WD for long distances (like the 2-day trek from Indy-to-Moab). Its also handy if you break a front diff...it allows you to get home without grinding internal parts into dust.
  16. #13
    Low Profile
    Join Date
    Mar 2012
    El Paso, TX
    Posts
    166
    Thanks
    19
    Can't tell but something to consider.
  17. #14
    Needs a sponsor
    Join Date
    Sep 2011
    Wilmington NC
    Posts
    41
    Thanks
    18
    Looking forward to the build.on another note; I see all these custom builds, just wish a company would pickup up the design and fabricate to the masses.
    Sent from my DROID RAZR using Tapatalk 2
    -Griff
    2007 Hummer H3 I5 Adv/lux, 33'' BFG KM2's, CBPhoto front winch shelf, Smittybilt COMP Series 10000 ilb winch, Custom Fuel Rack.
  18. #15
    Mud Terrain
    Join Date
    Jan 2012
    Cohoctah, MI
    Posts
    871
    Thanks
    300
    Cant wait...
    2008 H3, Leveled, 265/75/16 Goodyear Duratrac's, CBUCP, Air Doc, Aries Brushguard, Rola Roof Rack, Pro Comp ES 9000's
    Love Life, Live Life, and Love Your Hummer !!!!!!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
