There is not much to see when the hood is open - the kit replaces a part that comes on the original air box with it's own then everything else is in the inner fender, both the OEM unit and the new unit are just black pieces of placstic that pass through the factor hole in the fender so it all looks the same
I purchased one of first group great quality and easy enough to install. Even on 07. Only gripe and tip is the holes on template are about half inch off from actual snorkel. Had th open holes up a bit to get bolts to line up. Otherwise great deal.
They come with a small adapter that threads onto the existing antenna mount but it reduced signal strength on mine. The antenna will still bounce off the snorkel at highway speeds w/crosswinds or when offroading
