Spidermonkey
- Montana
A couple weeks ago when turning right and using the turn signal I got the fast blinking signal. I assumed that meant I had a bulb go bad. Before I could get it changed the same thing happened to the left signal. Both front signals work, but neither rear signal works. On top of that the rear lights come on, but do not brighten when braking. Again, makes me think one of the filaments in the bulbs has gone bad. I figure I have some burnt bulbs and replaced them. Well, lo and behold, new bulbs have the same issue. The left rear turn signal does not work, but when braking the light works. The passenger rear light now stays on even when the car is turned off and does not work braking or with the turn signal.
I checked all wiring, connections and fuses and everything looks good. I don't think it is a socket since both are acting up at the same time just in different ways. So I'm thinking it is the Body Control Module (BCM) that has a glitch and needs replaced. Any other ideas?
I've never pulled the BCM and tested it before, but I can't imagine it is too difficult. Any experience with testing or replacing the BCM?
