JonBishop
- Glendora, CA
its probably a very simple thing but how do i make it work? like the alarm wont sound when i lock the doors when i get outa the hummer, how do i make it work?
Here you go. :thumbs: I like the horn to sound so I know it has locked. RemoteKeylessEntry (RKE) FeedbackThis feature allows you to program the Remote KeylessEntry (RKE) feedback to a preferred setting.To set your choice for this feature: 1. With the engine off, turn the key to LOCK/OFF. Do not remove the key from the ignition. 2. Press and hold the lock and unlock buttons on the RKE transmitter at the same time. Hold both buttons until the DIC display shows the current RKE feedback mode 3. To view the next available mode, press and hold the reset stem until the mode appears. Release the reset stem and press and hold again to view the next mode. 4. Once the desired mode is shown on the DIC display, briefly press the reset stem to set your choice. The DIC display then clears. The following are the available modes: RFA 1 (default): This mode flashes the parking lamps when you press the lock or unlock buttons on the RKE transmitter. RFA 2: This mode flashes the parking lamps and sounds the horn when you press the lock button on the RKE transmitter. This mode also flashes the parking lamps when you press the unlock button on the RKE transmitter. RFA 3: This mode flashes the parking lamps and sounds the horn when you press the lock or unlock buttons on the RKE transmitter. RFA 4: This mode disables RKE feedback. There will be no feedback when you press the lock or unlock buttons on the RKE transmitter. |
#2 is where I'm having issues the DIC never lights up when I hold in the lock/unlock buttons on the remote! Anyone know what I might be doing wrong?
RemoteKeylessEntry(RKE) Feedback
KeylessEntry(RKE) feedback to a preferred setting.
feedback mode
next mode.
RKE transmitter.
RKE transmitter.
